scaling bugs at 4/1 setup
  • clash tv
    by clash tv » Sun Jan 10, 2010 10:03 pm
    hi garagecube team,
    i have a strange problem concerning simple scaling of a clip.
    i use a matrox THTG with 3 outputs. so my modul8 setup is 4/1.
    i have produced a clip with the dimensions 1024x256 (4/1)
    movie settings: quicktime,square pixel, fotojpeg 75%, 30fps
    the problem is: if i scale the clip with the uniform scale fader
    it is impossible to fill the output with this movie exacty.
    either on the left and on the right i see the background
    or i have a overlap on the top and bottom.
    the clip seems to be more narrow than the output.
    a also tested the fieldOfView knob, with no success.
    so is there a magic factor i have to add ?
    i have to produce videoclips for a videowall, which
    have to fit exactly to the output resolution.
    another strange scaling thing is:
    if i load the (4/1)clip into the layer with normalize , it dos
    not fit to the output. its alwas placed in the middle, scaled to
    a third of my output width.
    everything works as expected in a 4/3 setup.
    hub
    Re: scaling bugs at 4/1 setup
    by boris » Sat Jan 16, 2010 4:59 am
    Try this :
    Put the fild of view knob at the minimum and do a fine adjustment of the scale using the 'alt' + arrow key shortcut.
    or (more complicate) :
    Activate the normalize button, put the scale slider at the maximum with a scale factor 3x and the fild of view knob at the minimum.
    clash tv wrote:hi garagecube team,
    hub
  • clash tv
    by clash tv » Sat Jan 16, 2010 2:26 pm
    hey boris,
    thanks a lot for your explanation.
    putting the field of view slider does the trick !
    i thougt, that i have checked that ...
    now i can work pixel accurate :-)
    hub
  • clash tv
    by clash tv » Sat Jan 16, 2010 5:35 pm
    just for completition,
    if you want to set a pixelaccurate global mask
    in a 4/1 setup, a uniform scaled movie or image
    with a the factor 3. is a bit to smal.
    we dont have a field property here ...
    but the magic factor of 3.005 do the job.
    python code:
    modul8.setValue ('direct_globalMask_scale_uniform',3.005,0)
    h.
