What is the best USB device for controlling modul8????
  • vjjimmyjames
    by vjjimmyjames » Fri Jan 15, 2010 12:16 am
    He all
    I've had modul8 since like 2005 I think is when I bought it
    finally I am really getting Into it
    I project at concerts using a powermac g5 dual 2.5 with 4.5 gb of ram
    I want to use a USB device to control the program
    I have a USB device but can't figure out how to program it
    isthere one that is easy to use and easy to map?
    Is there a such thing as auto mapping?
    I am currently controlling everything with a mouse which is crazy
    and when I'm high and the music is really good it gets to be tedious
    any suggestions anyone
    the USB device I have is the m-audio uc-33
    i have no idea how to make it control modul8
    I would buy a better one if there is so ething someone knows of and is easier
    also, are there any mire effects in modul8
    I find myself running out of stuff to do at the shows
    Thanks for any help
    maybe I am too ADD
    peace
    james
  • vjjimmyjames
    I am an idiot
    by vjjimmyjames » Fri Jan 15, 2010 12:43 am
    Well, I am.
    I found a sick plug-in page.
    I still don't know how to use this MIDI USB device to control Modul8
    Any help would be awesome.
    Has nothing to do with mapping as mentioned in previous post
    Re: What is the best USB device for controlling modul8????
    by vanakaru » Fri Jan 15, 2010 1:32 am
    He all
    Thanks for any help
    maybe I am too ADD
    peace
    james
    UC33 works very well with M8. It is one of the most cost effective one - so many sliders, knobs for the money. It maps just like any other midi controller. You could use Enigma to program the layout, but this program(Enigma) is crap and works OK only some rare times.
    Mapping>Edit MIDI map>click on the element of M8 you want to map>move controller on your UC33. Thats it!
  • wobulation
    by wobulation » Thu Feb 25, 2010 11:36 pm
    when i turn the knob it sets it and sets a key like [1/28]
    then i stop mapping
    i move the knob and it instantly jump to 100%
    is there a way to make it more relative and not absolute?
    Is this what the midi relative module is for?
    How do i use it? all i see is a black rectangle with the title.
  • wobulation
    by wobulation » Fri Feb 26, 2010 8:52 pm
    Hey Guys after a ton of research, i decided to sell my current midi controller, and get one that works with modul8 better. So far ive got my peepers set on the maudio UC33. Are there any other controllers youve had good experiences,and are worth considering?
  • te-c
    by te-c » Fri Feb 26, 2010 9:10 pm
    I'm using the Behringer BCF 2000 before I've got the BCR. A mix of both were best with shorter faders but some more knobs with push-function.
  • anomad
    by anomad » Fri Feb 26, 2010 11:38 pm
    . i use the livid instruments ohm36 - nice collection of buttons/knobs/pads
    . i aslo pack a korg nanoKey for when i need 50 buttons (25 as notes/25 in CC mode) handy.
    -james
    (a nomad. )
    gilhoo
    by gilhoo » Sat Feb 27, 2010 11:49 am
    I'm using the very handy Korg NanoKontrol
    cheap, lots of buttons, knobs and faders and fits perfectly with a MB 13" ?
    It could looks like a playskool thing but it's not.
    If you are a brutal vj don't expect something very solid, it's not a BCF2000 !
  • wobulation
    by wobulation » Sun Feb 28, 2010 8:39 pm
    I really like the UC33 ~ Its in my price range an has the knob slider ratio that is best suited for my needs. THANKS!
  • moonbase
    by moonbase » Tue Mar 02, 2010 3:11 pm
    Apple extended Keyboard with Numeric Keypad.
    Hundreds of buttons available for key mapping.
    Use Shift to double up keys if you want, although Shift Lock has never worked with mine.
    Built in 16 pad Numeric Trigger Keypad for clip triggering.
    Multi-purpose.
    Cheap - £10 to £20 UK quid on Ebay and well built.
    Built in 2 port USB hub.
    User definable labelling... with stickers.
    Some of the keys come ready mapped to M8 - Up/Down arrows between layers and L/R arrows to fade layers.
    Map the M8 Masterfader Module (name?) to a couple of keys for really fast, user definable crossfading.
    If you reckon you really need faders, and I would argue that you don't, get a Novation Nocturn but...
    mapping gui knobs to the BPM in M8 and triggering them on and off with a keyboard key is all that's really needed,
    watch your working method and see how little you really use/need to use, faders!
    I've tried almost all the other options since M8 was V1 but this is the kit I always pack to go :-)
  • workhouse
    by workhouse » Tue Mar 09, 2010 6:15 am
    i am using 3 controllers ( 1 has sliders) one hitable pads and a monome
    and still run out of knobs that do what i want
    having experimented with touchosc on my iphone and made a couple of test templates i am more than curious to see wether an IPAD would replace at
    least 2 of my current controllers
    anyone else looking down that road?
    by ilan » Tue Mar 09, 2010 4:41 pm
    Intense? How do memorize all of the mappings?
  • workhouse
    by workhouse » Fri Mar 12, 2010 3:37 am
    lol thats like asking
    'how do you remember what all those piano keys do'
  • te-c
    by te-c » Fri Mar 12, 2010 9:47 am
