videoglide
  • jojosback
    videoglide
    by jojosback » Sun Jan 17, 2010 5:31 am
    Greetings all.. I'm trying to get my live cam feed to work in Modul8. I'm using the easycap device and videoglide software to recognize it on my mac. I am getting the feed into videoglide. However, when I try to switch the video capture source in Modul8, I see Videoglide listed, but I cannot select it. Any suggestions?
    Thanks :?:
  • VJnutcracker
    by VJnutcracker » Sun Jan 17, 2010 9:57 am
    Hi.
    http://www.garagecube.com/forum/viewtopic.php?t=3951
    This thread may help.
    What USB device have you got?
  • jojosback
    by jojosback » Sun Jan 17, 2010 5:15 pm
    Hi VJnutcracker.. I am using the EasyCap device with videoglide software. Again, I am getting the video signal into the computer but Modul8 will not allow me to select the source in video settings :?:
  • VJnutcracker
    by VJnutcracker » Sun Jan 17, 2010 6:44 pm
    from that thread..".EasyCap DC60+ v.3.1B. [thanks vanakaru] - 720x576 Pal, 720x480 NTSC. (not the DC60 v.2.1C - make sure it has a + sign after the DC60) "
    by vanakaru » Sun Jan 17, 2010 7:47 pm
    Try to make sure that no other app is using the EasyCap. You do not need to run VideoGlide to get this dongle to work in M8. I hope this helps. And try restarting M8 or your mac. If you see live image with Videoglide or QT you should get it to M8 as well.
  • viberation
    Re: videoglide
    by viberation » Thu Apr 05, 2012 10:12 am
    Thanks, I was fiddling with my EasyCap DC60+ for over an hour, no matter what I did it was grayed out in Modul8.
    Then I restarted my MBP, and *did not open the Video Glide software*. Just opened Modul8. It started working, Thanks!!!
