Dv is rather heavy decoding and has some other problems like interlacing, PAL and NTSC system differences. I suggest you to try a segment first. To decide over quality, file size and so on.Ok. Thank you!
I´ll try with that codec (as I was using DV) and let´s see.
Thanks... I use in fact Streamclip for some tasks, but as I´m not a video specialiced I would like to know what is esactly "deinterlacing"I have had excellent results deinterlacing movies with Streamclip.
If you use DV interlaced video you will get *tearing* artifacts specially if you have vertical and diagonal lines - as lamp post. It may be as bad as you get half of the post in one frame and the other half in the next. Its not about a performance in Modul8, but you video looks weird. Plus DV is much heavier on CPU. PhotoJPEG is basically a sequence of jpg photos thus it is very easy to manipulate and does not require much work to play.right now I understand but I don´t realice if I can do it with the "photo - JPEG" or only with the DV and (as I´ve tryed) if the sice of my videos doesn´t change after deinterlacing why should be better the performance of m8.
What´s "BTW"? (I can´t find it in my Streamclip popup menu, sorry, I´m not specialliced in video... Weren´t better the photo-JPEG format??You should export to QuickTime video BTW.
