freeframe help
  • workhouse
    freeframe help
    by workhouse » Tue Jan 19, 2010 2:56 am
    hi
    i am running the latest updates of everything on a new mac laptop
    its running supersmooth but for some reason
    none of my freeframe and iua plugs are remembering their
    settings , they just revert to their default settings
    i have tryed storing the plugs in the new plugs folder, the HD library, app support etc
    as i did in my old laptop but nothing seems to help
    any advice??
    thanks all
  • workhouse
    by workhouse » Wed Jan 20, 2010 11:24 pm
    bump
  • anomad
    by anomad » Thu Jan 21, 2010 3:47 am
    . hmm - it might be the filters you're using?
    . which version of modul8 are you using? i use v2.6 and could have sworn that some new free frame effects plugins i got were not saving the changes i made (to the point that i mentioned it to the developer) - but i started w/a clean slate and spent about an hour testing various save configurations and couldn't reproduce the problem -- all my changes were being saved. :?
    -james
    (a nomad. )
  • workhouse
    by workhouse » Thu Jan 21, 2010 5:47 am
    thanks for the reply nomad
    thats just it its a brand new fresh out the box laptop
    with NOTHING but brand new mod8, new freefilters
    idebticale ( as i can see) set up to my old laptop
    which saves them fine
    wish i could figure why
    as i have an important show saturday
  • anomad
    by anomad » Thu Jan 21, 2010 6:40 am
    workhouse wrote:new freefilters
    . which free frame filters are you using?
    . try a plugin, set all value left (or minimum) save project as test 1
    . use same plugin, set all values right (or maximum( save project as test 2
    . load test 1 - did the values return to where you expected them?
    . did you try copying the modul8 file from the working laptop onto the new laptop? do the filters load properly ?
    . also, what other modules are you using?
    -james
    ( a nomad. )
  • workhouse
    by workhouse » Mon Jan 25, 2010 9:38 am
    some petes plugins a pack of iua i bought, some basic freeframe package stuff
    nope all went to zero
    brand new install yes all the filters load properly and brand new installs
    the only thing i am never totaly certain is as to where they should be stored
  • anomad
    by anomad » Tue Jan 26, 2010 5:13 am
    workhouse wrote:the only thing i am never totaly certain is as to where they should be stored
    . the filters or the saved files?
    . hmmm. not sure. i guess you could try deleting your modul8 preferences or after you've saved the project, open it TextEdit and do a find (ctrl+f) for one of the parameters you changed to see if it's being saved.
    -james
    (a nomad. )
  • workhouse
    by workhouse » Mon Feb 01, 2010 3:35 am
    the filters
    so i tried deleting all the prefs reinstalling etc
    still no joy . the filters , petes and iua plugs
    revert to zero on each layer when i reload the project
    VERY frustrating indeed
    anyone any more suggestions would be most welcome
    dave
    david
    by david » Mon Feb 01, 2010 4:11 pm
    Hello workhouse,
    workhouse wrote:the filters
    dave
    I have tried to reproduce the problem with no luck.
    In Modul8 2.6.1 :
    - new project
    - assign video capture to layer
    - open Filter Module
    - assign (FF) Fisheye filter, change its parameter (radius, distortion, center)
    - save the project
    - quit Modul8
    - load the project
    - the filter parameters are using our new values
    Give us the steps to reproduce your problem. From our "point of view", it is working fine.
    Regards
    David
  • chrismac
    by chrismac » Tue Feb 02, 2010 5:51 pm
    try turning the module off or closing it before closing.. i had the same problem with the dmx module getting it to save a patch, but i noticed that modul8 only seems to save module information when it closes if the modules are turned off
