BPM SEQUENCER, COLOR CYCLER
    VJ_JeSs
    by VJ_JeSs » Thu Jul 21, 2005 7:19 pm
    We're on tour at the moment. And we spend a lot of time in the van going from a gig to another. Thank god we have a power plug in the van. So I have spent a bit of time coding modules. Its really good fun.
    So check out the sequencer. Its very good with clips with audio.
    Give me feedback on functionality so I can improve.
    Have fun ;)
  • jm302
    Re: BPM SEQUENCER, COLOR CYCLER
    by jm302 » Fri Jul 22, 2005 2:49 am
    Greetings,
    Could you try uploading your BPM Sequencer again? I tried instaling it a few times, but in each instance only a 4k icon ends up in my modules folder. The colour cycler works like a charm though, nice show!
    Cheers,
    Justin
    http://www.302acid.com
    VJ_JeSs
    by VJ_JeSs » Fri Jul 22, 2005 8:49 am
    ok should be fixed ;)
  • jm302
    by jm302 » Fri Jul 22, 2005 7:46 pm
    BPM Seq isn't in the public library anymore.
    j.
    VJ-A2D
    by VJ-A2D » Fri Jul 22, 2005 9:33 pm
    same thing here...
    Plus2 Collectiv
    VJ_JeSs
    by VJ_JeSs » Tue Jul 26, 2005 5:46 pm
    Help guys, Yves, Boris. I'm trying to upload this Sequencer module. But its not working. It takes ages to upload on my 56k modem. But never appears in the list. It only did appear once. But that was after I forced quit modul8 because I thought it was stuck uploading (apparently it wasn't, and only part of the module uploaded).
    Could it be a size limit for module uploads. I'm not sure why; but the sequencer module is quite big (3,9 meg)
    Thx :)
    by boris » Tue Jul 26, 2005 10:21 pm
    I dont know what is the problem...
    Actually the limit is fixed to 16 MB.
    Can you try again ?
    VJ_JeSs
    by VJ_JeSs » Wed Jul 27, 2005 11:28 am
    Well, I tried again this morning. Still no luck. It uploaded for about 10 minutes (seems right for 4 meg on a 56k modem). But then nothing appeared in the list of shared modules :(
    Sorry guys but I think I'll be the only one to enjoy this sequencer. Althoug I suppose I could just upload it to my webspace and share it the regular way. But I'm not sure its the right thing to do.
    Maybe I could e-mail it to Boris or Yves and let you try and share it ???
    bye for now
    VJ-A2D
    by VJ-A2D » Wed Jul 27, 2005 12:26 pm
    it would be nice to get a hand on it... i started to work on one... but since you have a finished one :) i'm waiting to take a look at it.
    Plus2 Collectiv
    by boris » Wed Jul 27, 2005 3:22 pm
    bye for now
    Yes send me your module, also we will be able to test the upload.
    VJ_JeSs
    by VJ_JeSs » Sat Jul 30, 2005 4:20 pm
    Boris did you receive my e-mail ?
  • Akira
    by Akira » Tue Aug 02, 2005 7:47 pm
    I'd love to have this module, please post it ASAP on the library!
    VJ_JeSs
    by VJ_JeSs » Wed Aug 03, 2005 12:21 am
    yeah its a great module :) But sorry Akira apprently it doesn't want to upload. Even Boris can't get it on the server. Or maybe he wants to keep it to himself ;)
    Something to do with the size. But a compression sheme is apprently under way for the modules (in the next update). And then it should be fine (correct me if I'm wrong, boris, yves)
    yves@garagecube
    by yves@garagecube » Wed Aug 03, 2005 12:26 am
    Yea, we have a problem with the server yet. You just can't upload a module bigger than approximatively 3.5 megs. Anyway, the next Modul8 version will compress modules before uploading them to the online library. It should solve the problem and also use much less bandwidth. Sorry for that...
    Last edited by yves@garagecube on Tue Aug 09, 2005 9:52 am, edited 1 time in total.
  • Akira
    by Akira » Mon Aug 08, 2005 11:57 pm
    cant the module be put onlien somewher so we download it manually?
