Mrmr
    nestor
    Mrmr
    by nestor » Mon Feb 01, 2010 11:57 pm
    Someone tested the mrmr (ipod touch) with Modul8? I can not make the connection. M8 version is 2.5.10, the program is free!
    by vanakaru » Tue Feb 02, 2010 8:36 am
    I was not able to do it long ago. Also it seemed to become a dead project. I remember it use OSC so you may want to get your osc converted to MIDI. OSCulator is for that.
    I am sure you have a reason to use mrmr, but since then I use TouchOSC and OSCulator. You can create your layout as well with TouchOSC.
    nestor
    by nestor » Tue Feb 02, 2010 4:03 pm
    I'm trying the touchosc but I can not upload the layout to ipod, i use osculator (test), and I'm trying to factory layout and it works ok. but I like to do mine, I put add layout, sync from the program but nothing happens.
    danzacf
    Mrmr works...beautifully
    by danzacf » Wed Feb 03, 2010 7:42 pm
    Hola, from sunny South Africa. I've been using mrmr for almost a year now, ever since I got my iPod touch, and I find it fantastic. No longer do I have to sit at my midi triggers, now I can mix and trigger wirelessly from the dancepit.
    For me the secret was osculator. Once you've got the mrmr server/client connection going osculator will translate the mrmr OSC arguments into whatever you need, midi or keywords!
    From there the possibilities are endless.
    Coincidently I find that an iTouch and a wiiMote are a fantastic combination for really tactile visual manipulation. Now if only I could get a better camera to get my 3rd world reactable as sensitive as I'd like it.
    Daniel Zachariah Franks
    everyman his own football
