how to sequence show without a midi sequencer?
  • skipzone88
    by skipzone88 » Tue Feb 02, 2010 7:43 pm
    How do i sequence a show of video works without a midi sequencer? Or is there a basic midi sequencer i can get for the mac? I am not a music maker so i don't have a keyboard or logic audio.
    i want certain films to play at certain times of the day. i want them to dissolve into one another.
    DIGITAL VIDEO PROCESSING depuis 1988
    by vanakaru » Wed Feb 03, 2010 10:36 am
    Numerology is an excellent one. Or PatternSequencer that is free.
  • mowgli_uk
    by mowgli_uk » Wed Feb 03, 2010 12:05 pm
    If you want films to play at certain times of the day I don't think it's a sequencer you're after. You're probably better off with some basic custom software. You could try to make something with Quartz composer which comes free with your mac os or maybe you could build a module for this?
    by ilan » Wed Feb 03, 2010 12:38 pm
    Or you could simply use the 'SlideShow' module and enable 'wait movie' so that it plays the current movie all the way to the end.
  • skipzone88
    by skipzone88 » Wed Feb 17, 2010 12:12 pm
    I am going off topic now as i have got a midi sequencer! which is great!
    using numerology2 how do i control the value of a knob? i can successfully trigger films to play and switch, but i need to adjust the opacity of a layer over a duration of the sequence.
    I have tried mapping a pitchbend to a key but that doesn't seem to work.
    also it would be great to be able to pause the movies with timecode display at the playhead in numerology2.
    i am getting into this!
