Sound input low mid and high BUGS
    ledude
    by ledude » Wed Feb 10, 2010 3:28 pm
    Hello
    i was very happy to have the new version 2.6 with this new Sound input (mid low ang high).
    I try it, all seams to go very well.
    And suddendly modul8 sound input doesn't work anymore.
    The equalizer from sound analysis works. But there is no signal in low mid and high and the input sound level works.
    I must restart the software and it works normally again.
    I try it many times and always the same problem.
    THE SOFTWARE crashes DOWN one time! First time i see modul8 crash.
    I'm working on a Mac book pro with 10.4.11
    the sound comes from itune with soundflower to modul8
    Any idea?
    What can i do?
    Thank you.
    by ilan » Thu Feb 11, 2010 10:48 am
    ledude
    by ledude » Thu Feb 11, 2010 12:50 pm
    ok thank you for the link
    I must upgrade my system 10.6 to be sure: GRRRRR..
    and upgrade sound flower 1.5
    I make many try and i found some half solution (it works better)
    so i make cross over songs in Itune (between the song modul8 loses the signal), and sound level adaptation.
    i make an update from soundflower in 1.4.7 (OSX tiger)
    it works but i must be carefull not to add many layers or different videos and effects and I think that my camera input took many ressources and crash down the software.
    so my report and tests.
    Maybe it can help.
