Project doesn't save clips in layers
  • imwinkel
    by imwinkel » Sat Feb 13, 2010 8:42 pm
    Hello
    I create a project with version 2.6 assigning different clips to different layers. When I save the project and then re open it, all clips assigned to layers are the same. Basically, Modul8 seems to be unable to save information concerning which clip was assigned to a specific layer.
    I feel problem is a bit difficult to explain.
    For example, in the image below all the clips are clip number 1, the same clip called LOGOMACADAMSMALL. The project I created had different clips in each layer. After saving and reopinging, I find that all the clips are same!
    Since new version, all the projects I've created are like this--unable to properly save.
    I would appreciate some help at your earliest convenience. Many thanks!
    by ilan » Sun Feb 14, 2010 1:04 pm
    Hello imwinkel,
    Can you send us an email at support at garagecube dot com along with your serial number?
    Kind regards,
    ilan
