Problem with checkboxes in modules from library.
  • schismatrix
    by schismatrix » Fri Feb 19, 2010 12:12 am
    There is one problem with keyboard shortcuts.
    When I use a keyboard shortcuts for checkboxes in main panel all works fine.
    But when I use shortcut for checkboxes in additional modules from Online Library it works next way:
    If checkbox is off and I pushing a key, it turns on.
    But after I release the key it stands off again.
    How make chekboxes in additional modules switch on / switch off by single key pressure?
    david
    by david » Fri Feb 19, 2010 3:57 pm
    Hello shismatrix,
    this is a bug... could you report it to support [at] garagecube [dot] com ?
    We will provide you with a patched version of Modul8.
    Regards.
