Button script.
  • Teh-B
    Button script.
    by Teh-B » Sun Feb 21, 2010 11:44 am
    Hi. I'm newbie in scripting.
    Because of some features of my midi-controller I would like to create a button in module which will turn on/turn off a checkbox.
    First push - turn on.
    Then release of the button make nothing.
    Second push - turn off etc...
    I created a button with massage OnOff and tried to use next script:
    if msg == 'OnOff':
    parameter = module.getValue ('NameOfCheckbox',0)
    if parameter == 0 :
    module.setValue ('NameOfCheckbox', 0,1)
    else :
    module.setValue ('NameOfCheckbox', 0,0)
    But with this script when I push the button checkbox turns on
    but when I release the button checkbox turns off.
    Which code should I use?
  • Teh-B
    by Teh-B » Mon Feb 22, 2010 7:10 am
    I've found the answer:
    value = param['value']
    if msg == 'OnOff' and value != 0:
    OnOffAParam = module.getValue ('enabled1',0)
    if OnOffAParam == 0 :
    module.setValue ('enabled1', 0,1)
    else :
    module.setValue ('enabled1', 0,0)
