Speed Percentage
    madsmeskalin
    Speed Percentage
    by madsmeskalin » Thu Feb 25, 2010 9:15 pm
    Hi! I desperately need some help. I have made a bunch of content to 120bpm (start and end points) , but since I will be playing at a psytrance party in a couple of days I really need some help.Is it any module or any workaround to either
    A) increase speed of the clips/master by percentage? (13% speed increase) OR
    B) Similiar to A, just with BPM (I know my clips are 120bpm, so I can increase speed with 10bpm), OR
    C) Match in and out points with BPM router.
    by sigmasix » Fri Feb 26, 2010 10:41 am
    1. set your layer speed to zero
    2. set the BPM module to 120 bpm
    3. using the BPM router LAYER, pick the left knob in the "play" controls
    4. set the anim type to IN
    5. click play
    then you can use the 4/1, 2/1, 1/1, etc. buttons to quickly change the speed.
    madsmeskalin
    by madsmeskalin » Sat Mar 20, 2010 9:01 pm
    Thanks Sigma!
