One license two users?
    madsmeskalin
    by madsmeskalin » Tue Mar 02, 2010 11:12 am
    Im Vjing with a friend, and he asked me if he could get a copy of my modul8. I know that you can install modul8 on two computers, but does it have to be the same user, or can two different users use the same license?
    best ergards,
    Mads Meskalin
    by ilan » Tue Mar 02, 2010 2:18 pm
    1 license if for 2 computers. This means that you can authorize modul8 on 2 computers.
    Please be sure to de-authorize modul8 from a computer if you want to remove it.
    madsmeskalin
    by madsmeskalin » Wed Apr 07, 2010 11:10 am
    But does that mean that for example I can buy a lciense with one of my friends, and we can both use it at the same time?
    madsmeskalin
    by madsmeskalin » Wed Apr 07, 2010 11:11 am
    Or does that mean that both computers have to be mine?
    by ilan » Wed Apr 07, 2010 11:18 am
    You can authorize modul8 on any computer you like. Just be sure to de-authorize it when you are no longer using it on that computer. Simply putting into the trash will not de-authorize it from the computer.
  • lamepantallas
    by lamepantallas » Sat Jul 24, 2010 8:37 pm
    Hi ilan,
    I just got my new computer and want to use modul8 in both my new and old one. When I register M8 in the new computer with my serial, will it cancell or block my old one through the internet or will it run just the same as before with no problem? I dont want any surprises when I go off to an event and find out it is blocked in either computer =)
    gabbo
    twitter.com/ @popversus
    by ilan » Sun Jul 25, 2010 7:53 pm
    Hello madsmeskalin,
    You need to contact support at garagecube dot com and we'll de-authorize for you.
