MiniDisplay Port to composite?
    cheveria
    by cheveria » Thu Mar 04, 2010 9:02 pm
    Hi there everybody.
    I just got my new MacBookPro 17" and Mac did some changes from the previous MacPro i had. Instead of DVI port they change it to Minidisplay Port.
    Is there a cable Minidisplay port to Composite video.???? Or how do i solve this unexpected problem????
    I have a gig soon, i need my computer up and running!
    PLZ HELP.
    Hard labor kills, i just VJ instead.
  • te-c
    by te-c » Thu Mar 04, 2010 9:07 pm
    Use a Mini-Displayport to VGA cable and a scanconverter to use Composite.
    cheveria
    by cheveria » Thu Mar 04, 2010 9:21 pm
    I see, but, dont you think i will loose quality 2 connections, so such a thing doesn't exist MiniDisplay Port to Composite???
    Thanx anyway.
  • te-c
    by te-c » Thu Mar 04, 2010 11:45 pm
    I dont't think that you will much quality. BTW I'm using VGA only, cause of better quality than Composite.
    cheveria
    by cheveria » Fri Mar 05, 2010 12:48 am
    true that. thanx.
