USB connection lost after few minutes
  • stivo
    by stivo » Sat Mar 06, 2010 6:04 pm
    Hi!
    I use these M-Audio Trigger Finger USB MIDI devices.
    But since Modul8 2.6
    These only work for a few minutes. (About 4)
    I Have 2 of them both same issue.
    My setup:
    - OLD model MacBook Pro
    - issue on both SB ports
    - Issue on both TriggerFingers
    - Changed cables
    Other software: Like Traktor functions fine with same setup / hardware.
    When the issue persists: Disconnecting en reconnect the TriggerFinger and it works again for a few minutes.[/img]
    by vanakaru » Sat Mar 06, 2010 6:41 pm
    sounds like USB overuse. Look at system profiler how your USB ports are used. Even if you have many physical USB slots they may be using the same USB port.
