. anyone using direct_snapshot_previewWindow ?
  • anomad
    by anomad » Sat Mar 13, 2010 9:16 pm
    . and if so, how does it work? where does it store the image?
    . i could've sworn i saw a post about this in the past but i have been unable to find it.
    . thanks!
    -james
    (a nomad. )
    by sigmasix » Sun Mar 14, 2010 2:25 am
    it acts the same as the snapshot you can get from the Render menu. You can choose the location where to save the screenshots in the preferences, under the Misc tab.
  • anomad
    by anomad » Sun Mar 14, 2010 9:35 pm
    . hmmm.. still not seeing any images taken - i have a button that takes a snapshot, the code i'm using is :
    if msg == 'takePic' and param['value'] == 1.0 :
    modul8.setValue('direct_snapshot_previewWindow', 1)
    print "got a picture..."
    . but nothing appears. is that the correct way to use direct_snapshot ?
    -james
    (a nomad. )
  • anomad
    by anomad » Mon Mar 15, 2010 4:35 am
    . replying to myself since i figured it out...
    . this line :
    . should have an extra 0 at the end, like so :
    modul8.setValue('direct_snapshot_previewWindow', 1, 0)
    . when in doubt, add another 0 to the setValue command parameters. :wink:
    -james
    (a nomad. )
    by sigmasix » Mon Mar 15, 2010 9:10 am
    yep… the module documentation is not very precise about that, but the setValue neets to receive 3 falues (keyword, value, layer). Even if all these values are not needed. getValue needs only two (keyword, layer)
