Modul 8 Filter (Layer) - Duplicate problem
  • bc-vnbc
    by bc-vnbc » Fri Mar 19, 2010 11:02 am
    Hi All!
    We have a little problem with this great software!
    We are using modul8 v2.6 1007
    When we duplicate layers, all filters and scaling (via transform) it reset all ...
    Also, when I re-open a project, the first filter is still good, but the 3 others are not working.
    I thaught this problem was over with this version (At first, I had no bug like this)
    - Is there a way to work around this ?
    - Should I build a module for this ?
    - Can you point me a real way to deal with this ?
    Thanks !!!!!
  • bc-vnbc
    by bc-vnbc » Thu Mar 25, 2010 7:44 pm
    bump
    After a bunch of tests, modul8 is able to save preset on the first filter of each layer but not on the top layer though (thanks for pointing this Ilan)
    But what is this module for ??? If we can't save presets, I mean, all, there is no way to use this in live.
    And for us, it means no use of modul8 in live.
    Please help us!
