auto move diagonal / exit full screen
  • beatles
    by beatles » Fri Mar 19, 2010 5:28 pm
    I've a simple picture of a plan. I would like to set the auto move modus for this picture.
    Is there a possibility to move the plane diagonal?
    standard is only left/right, top/bottom or both. but how can I move an object diagonal?
    I use modul8 version 2.0. for exit of the full screen is this hotkey given: Image
    which key is this on the keyboard? if I only work with one screen (laptop), I can't get out of the full screen.....
    by ilan » Sat Mar 20, 2010 6:13 pm
    Hello beatles,
    - Try the L-BPM Mover. You can set the animation to any angle.
    - That would be the 'esc' key.
    Best,
    ilan
  • beatles
    by beatles » Mon Mar 22, 2010 6:11 pm
    hi ilan
    thanks for your reply....
    L-BMP Mover is this an additional modul? or where I can find this one?
    the "esc" key doesn't work. it must be another key...?
    by ilan » Mon Mar 22, 2010 7:40 pm
    Its in the online module library in the public section.
    by vanakaru » Mon Mar 22, 2010 10:42 pm
    V.2.0 (2000!?) is so long ago so I am not sure what was the key. But there was a manual for it. In some point the keys were changed to U and T. So if you do not have manual or you do not want to run newer version try cmd+any key until you get the right one. And do not doubt Ilan, he would know if anybody.
    And forget BTM modul, it was not created then and will not work with your version of M8.
