Chaos of modules if I set up the beamer
  • te-c
    by te-c » Sat Mar 20, 2010 12:42 pm
    If I have a second monitor or beamer on the computer and start up M8 all the modules are in a chaos on the srceen. I think I've read something about it that it isn't so but can't find it. Maybe you can help me.
  • mowgli_uk
    by mowgli_uk » Tue Mar 23, 2010 7:48 pm
    I think that happens when you've arranged all your modules but never had a second output plugged in. If you arrange all your modules with a second output plugged in they should remain where you left them although sometimes weird things do happen.
    by sigmasix » Tue Mar 23, 2010 10:35 pm
    the best rule to keep: Quit all your apps before pluggin a screen… it's the same with adobe products… you end up with all your palettes on the wrong screen… in modul8 you can have all your modules on the wrong screen…
  • te-c
    by te-c » Wed Mar 24, 2010 9:13 pm
    Thanx, hope it works.
