DVI output of second Macbook as live input
  • speakerfood
    by speakerfood » Wed Mar 24, 2010 1:41 pm
    I'm trying to achieve the following, and hope you guys can help:
    I need the monitor DVI output of a second macbook that is running Skype as the live input for a macbook that is running Modul8.
    This without too much delay, otherwise audio and video of Skype will get out of sync.
    by vanakaru » Wed Mar 24, 2010 9:47 pm
    The most easy solution would be pointing webcam attached to your macbook with M8 to your skype macbook screen and take audio direct line or mic in.
    Anything else involves too much voodoo to take seriously.
  • Decart
    by Decart » Wed Apr 07, 2010 5:56 pm
    Or you could use a DVI-VGA cable and a device called VGA2USB.
    http://www.epiphan.com/products/frame-grabbers/vga2usb/
    It's a bit pricy though...
    by vanakaru » Wed Apr 07, 2010 8:59 pm
    Decart wrote:Or you could use a DVI-VGA cable and a device called VGA2USB.
    I have not heard it would work but with desktop static - no streaming video. Too slow!
  • Decart
    by Decart » Thu Apr 08, 2010 9:03 am
    "VGA2USB software makes it possible to save and print captured images, to setup a periodical "save" command to capture images to disk or record an AVI file (Windows platform only). In addition to that, VGA2USB software is compatible with DirectShow on Windows and QuickTime on Mac OS X, which allows third-party applications to use VGA2USB as a video input."
    by vanakaru » Thu Apr 08, 2010 9:49 am
    I know that really works:
    http://www.matrox.com/video/en/products/mxo2_mini/
    with Express card to your MBP you get excellent framerate - latency. I tested it at the reseller her in town. But costs even more - about 500USD.
