audio output troubles
  • littleradiohead
    by littleradiohead » Tue Mar 30, 2010 11:52 pm
    hello! new here - not sure if this is the right place for this question, but i'm getting pretty frustrated from a few hours of searching on google.
    i have a MBP running 10.6.1 and I cannot get 'live' or 'dynamic' audio to output of out m8 whatsoever.
    I can load in quicktime files and get my sound to output just fine, however I cannot get my internal microphone to output, nor playing a tape through a DV deck
    I have adjusted the sound input and output knobs on the lower right corner, I can see my audio input in my system preferences and I just tried the sound viewer tool module and it shows the volume levels in my mic.
    but for the life of me, i can't get the audio to output to anything!
  • mowgli_uk
    by mowgli_uk » Thu Apr 01, 2010 3:48 pm
    What do you mean "get the audio to output to anything"?
    The audio input is only for fx control etc NOT to record or route incoming audio.
  • littleradiohead
    by littleradiohead » Thu Apr 01, 2010 7:35 pm
    Whenever I play a clip of something, the audio will output to my speakers, or my line-out or whatever I have it set to.
    If I have incoming live audio through firewire - or through a MOTU - it does not output.
    Is there a setting I'm missing somewhere?
    Thanks for your response!
  • anomad
    by anomad » Fri Apr 02, 2010 3:51 am
    . i use motu digital performer so i *think* i know what you're asking...
    . you'll need a sound pass through application to 'route' sound to your system's audio out . i use soundflower1.5.1 on os x10.6.2 -BUT - it craps out about every 45 minutes or so.
    . when using audio in, make sure the the audio in knob in the main interface of modul8 is turned up.
