Frame incrementer
    Frame incrementer
    by ilan » Mon Aug 01, 2005 10:09 pm
    Hello module makers,
    Can someone write a module with a button that advances a clip every time it gets pressed? This way one could just 'tap' advance a clip.
    Thanks in advance,
    -ilan
    VJ-A2D
    by VJ-A2D » Tue Aug 02, 2005 9:23 am
    hmmm aren't the scrath buttons enough ?
    Plus2 Collectiv
    by ilan » Tue Aug 02, 2005 3:08 pm
    They are rather innacurate. I am working with very synchronized content. Most of my clips are composed of say about 2 to 30 frames and each one has very specific content in a specific sequence. For example if the song says "I-am-being-beaten-down-by-the-pol-ice-state" each part of this line would be a separate drawing and would have to be displayed for a specific amount of time. Because the pauses between each word are improvised I have to be very responsive. Sure I could fill my media bin with two or three images but when I have a very long sequence the bins would be very difficult to run through. I don't have enough buttons on my Trigger Finger.
    Understand that I am working with a musician where every song has it's own set of visual content. For this work the module have been essential. We almost have a custom module for each song.
    Guess I'll just have to figure out how to write it myself. :)
    by sigmasix » Tue Aug 02, 2005 6:09 pm
    I did it, I'll post the module in the online library as soon as we made some tests 8)
    by ilan » Tue Aug 02, 2005 6:51 pm
    You officially are the master module maker. And I owe you a potrait.
    -i
    by sigmasix » Thu Aug 04, 2005 8:14 pm
    I think the master stills boris :lol: :lol:
    I uploaded the module in the online library (senteriology) I hope it works as you wanted.
  • vj123
    by vj123 » Sat Apr 08, 2006 9:55 am
    hi !
    maybe you can give my module "EasySelection PLUS" a try and maybe it does what you need ??
    it depends a lot of the values that you enter in the module AND of the length of your movie !!!
    for example :
    here are the values that works fine for a movie that has a length of 2 seconds :
    original speed of your movie = ZERO
    easySelection PLUS :
    LENGTH : 0,0005
    POSITION JUMP VALUE : 0,02
    now you can use the jump buttons ( ">" and "<") to jump to the next or the last frame of your movie !!
    if you have a movie with another length you have to play a little bit with the LENGTH and the POSITION JUMP VALUE to fit it to your needs.
    you can also use the memory / recall buttons to jump directly to stored 'words' (=frames) in your movie.
    is this a solution for your problem ?
    by ilan » Sat Apr 08, 2006 7:36 pm
    Hey! That sounds very useful. I checked the library and downloaded you module. It's nice. Nice interface too. Could you upload the PLUS version?
    Would like to try that out.
  • vj123
    by vj123 » Sat Apr 08, 2006 11:59 pm
    hi senterio !
    not sure if i understand your last post.
    did you already downloaded the PLUS version ?
    i did upload it to the library.
    i'm working at the moment at a new feature to trigger automatically the random position and the jump buttons. i will upload later.
    have fun with the modul :)
