Screen real estate
    Jesper Fryd
    Screen real estate
    by Jesper Fryd » Mon Aug 01, 2005 10:43 pm
    So guys:
    How do YOU layout your Modul8 screen?
    The reason I am posting in the modules forum is that the modules are the source of the "problem". (Luxury problem , I know!)
    I quickly found myself not being able to cram all the lovely modules in there with the main interface.
    Any bright ideas?
    I am on a PB15" (1280*854)
  • jm302
    Re: Screen real estate
    by jm302 » Tue Aug 02, 2005 7:05 am
    Any bright ideas?
    My solution to this problem has been Exposé (look in your system preferences if you don't know what this is)... I set the lower left corner to expose all open windows. Works like a charm.
    Cheers,
    Justin
    http://www.302acid.com
    Jesper Fryd
    by Jesper Fryd » Tue Aug 02, 2005 9:02 am
    Any bright ideas?
    Cheers,
    Justin
    Hmm - clever 8)
    But doesn't Expose affect the second screen?
    VJ-A2D
    by VJ-A2D » Tue Aug 02, 2005 9:27 am
    hej jesper :)
    Did you try desktop manager out:
    http://www.macupdate.com/info.php/id/12682
    Plus2 Collectiv
    VJ_JeSs
    by VJ_JeSs » Tue Aug 02, 2005 12:27 pm
    Yeah its becoming a problem for me too.
    I've also rebuilt some of the modules to fit them in a 260 pixel wide window. Thats the space I've got left on the left side of the screen on my 15' powerbook. But thats only usefull to people with the same computer :?
    I'm also building all my modules with that in mind (130 or 260 pixel wide).
    Another good thing would be to create a master BPM module. So we don't have all the BPM buttons in many modules, it eats up a lot of space on the screen.
    And I'm also thinking of writting some sort of matrix for the layer selection. Many modules have got that layer part. And it would be good to put them all in the same place too. Like a last module at the bottom of the screen to select wich effect goes to wich layer.
  • Akira
    by Akira » Tue Aug 02, 2005 7:57 pm
    It's becom so much of a "problem" that I'm even thinking about reworking the whole interface for my needs.
    Hey, modules rock, it would be possible, so why not? ;) But I know it's be quie a pain in the botty to manage it. Someday...!
    VJFranzK
    by VJFranzK » Wed Aug 03, 2005 11:38 am
    I'm using that one also. ;)
    i float the extra modules on either side, or when in fullscreen mode, use that extra space for another module
    yes, think small & efficient for module controls
    Window focus
    by The Midi Thief » Mon Oct 10, 2005 10:15 am
    I was thinking if it's possible to use Python to put a module in focus? In that case I could map the focus function to a key and simply show the module with a key stroke whenever I need it. Then it wouldn't matter if it's hidden behind the main interface from time to time.
    I have looked around on python.org in order to find a solution, but since I'm new to Python I haven't figured out how to access the module's window object. Any help here?
  • moonbase
    by moonbase » Mon Oct 10, 2005 7:16 pm
    Exposé works brilliant for me too jm302, plus is dead simple to sort to suit your own style.
    It doesn't affect my 2nd screen Jesper, no worries there even using iBook+hack.
    I have it set to 'exposé' using the fn key, bottom left keyboard,
    I find there is less chance of stuff happening in error by using
    keys rather than 'screen corners', personal pref though.
    - a quick ket press at any time (fn key is easy to find in the dark)
    and each part of the main interface plus all open modules slide open
    to choose from, click the module you want and the main interface
    slides back into place with the selected module on top automatically.
    Luverly!
    Once you click back on the main interface the modules all disapear
    behind until needed again.
    as a sort of related question! -
    Is there way of triggering the modules 'all stop' option from a key?
    Now that would be a worthwhile trick.
    :P
    yves@garagecube
    by yves@garagecube » Mon Oct 10, 2005 7:53 pm
    :P
    Hmmm.... no, you can't do that...
    Yves.
  • skyvat
    by skyvat » Tue Oct 11, 2005 6:16 am
    :P
    Really? I just tried expose on both a G5 and a powerbook and it moves the output screen. Don't think i could have that in a show.
    What's your secret? :shock:
    bassballs
    by bassballs » Tue Oct 11, 2005 9:00 am
    :P
    I have today tested expose´, and like Jesper, my output is also moved. PowerBook 15#
    ~ Anders
    yves@garagecube
    by yves@garagecube » Tue Oct 11, 2005 9:56 am
    We'll try to that change for the next version. The output window should not be affected by Exposé.
    Don't know how Justin is using it right now, but there is maybe a shareware which allows you to exclude a screen from exposé...
  • moonbase
    by moonbase » Tue Oct 11, 2005 11:49 pm
    Exposé works brilliant for me.
    OK, I have been looking for a 'complete plonker' smiley everywhere but can't find one!!
    :oops: that will do...
    I just got in & read the M8 posts and have fired up my laptop all the while thinking
    'I'm sure XposeA works for me' - of course it doesn't, no secret, sorry!
    BUT The good news is that I then sussed a Key Map for the +/- in top left of M8,
    this works perfectly, NOT mapped to the fn (for some reason it wasn't having that I remember) but to the ctrl key.
    Now your interface will zoom out of the way leaving any open modules displayed.
    hope that helps! I have been using this mapping since V2 arrived .
    I am putting my lapse of memory down either to excessive cooking with aluminium or vast age.
