change Layerset group A/B at the same time with one click
  • neils
    by neils » Wed Apr 14, 2010 6:35 pm
    I try to change one of each A/B-layersets at the same time with one midi-key. Is this possible? For example: change Layerset A1 and B1 with one click.
    At the moment, I can only map one layerset to my midi-controler.key.
    Does anyone have a solution?
    Thanks,
    neils
    wygiwys
    by wygiwys » Thu Apr 15, 2010 9:07 am
    I know you can put multiple 'keywords' under one button (in a modul), and maybe you can link that button to midi?
    But I think you should look into using keywords, because then it's possible.
    What You Get Is What You See
    WYGIWYS.tv
    by ilan » Thu Apr 15, 2010 10:09 am
    I just uploaded a module that does just that and a few other small things that I use on a regular basis for my vj sets. Its call DC - nothing and its in the public section of the online library.
    tdog
    by tdog » Thu Apr 15, 2010 1:54 pm
    thanks for this - but it's in the garagecube libray......
    peace
  • neils
    by neils » Sat Apr 17, 2010 10:58 am
    Hi Ilan,
    thank you. This is exactly what I was looking for.
    Greets,neils
    by ilan » Sun Apr 18, 2010 1:08 pm
    True dat tdog. I moved it over to the public b/c its not an official Gcube module. Thanks for the note.
    You're welcome neils.
