Mini Displayport to S-Video
  • meiso
    by meiso » Fri Apr 23, 2010 5:20 am
    I know this is a bit off-topic but hopefully some ppl here have some solutions!
    Other than buying a third party box that requires power.. How the heck do I get a signal from my shiny new MacBook Pro Core i7 to S-Video???
    I was given a Mini Displayport to VGA adapter by a friend of mine which i can use with a very long VGA wire but i'd prefer to not have to lug around a 100' VGA wire to every one of my gigs..
    HELP!!
  • te-c
    by te-c » Fri Apr 23, 2010 8:41 am
    You can buy a shorter VGA cable, don't think that you must have 100 meters every time.
    The only solution for S-Video Signal is a scan converter. There's no other way.
  • meiso
    by meiso » Sat Apr 24, 2010 1:26 am
    I suspected as much.. I have ordered a mini scan converter that uses power from a USB port.
    Apple makes such good products, but sometimes they make really stupid mistakes.
    wygiwys
    by wygiwys » Wed May 05, 2010 4:10 pm
    Yeah, just get a scan converter for $40 or so...
    Most of them have got vga in, vga out, composite out, s-video out and are fed by usb
    Just google around to find some kind of electronics shop nearby.
    Don't get a professional one, these will cost you around $2000
    I think there's quite a market if you will just produce a displayport > s-video/composite box, apple sucks in switching their video output ports in every model.
    What You Get Is What You See
    WYGIWYS.tv
    by vanakaru » Wed May 05, 2010 6:50 pm
    I disagree. Do not get the cheap scan converter, sooner or later you will throw it to the wall - hopefully not at the show. Ebay has very good scanny's for under 100USD even you may get one for the price of the crap. Search for ScanDO Pro.
    deepvisual
    by deepvisual » Wed May 05, 2010 7:18 pm
    sadcrew
    by sadcrew » Fri Jun 25, 2010 9:42 am
    I bought this converter and I'm happy with it:
    http://www.selectronic.fr/upload/produi ... e/7056.pdf
    It cost something like $80 which is not really cheap though..
    Arnaud
