How to record during a show ?
  • traitdelumiere
    by traitdelumiere » Wed May 12, 2010 2:19 pm
    I'm looking for a way to record live events in real time.
    > capture to disk loses frames and logical record is difficult to use during a show
    1) I thought first to use firewire as a monitor (like does Final cut Studio)
    It would be fantastic to assign a firewire output via the "advanced output setup" in Modul8, and use any dv recorder!
    Is there any way to do it or anything similar?
    thanks
    Re: How to record during a show ?
    by vanakaru » Wed May 12, 2010 3:01 pm
    [quote="traitdelumiere"
    [/quote]
    No, it would not. The smooth performance is what makes M8 different from others. This would add glitches for sure.
    The best recording your performance is using split your VGA/DVI output to projector and scan converter then to recording device(computer, HDD recorder, Camera).
    There are now devices that allow VGA capture to computer. A good one is Matrox MXO2 mini
    http://www.matrox.com/video/en/products ... mxo2_mini/
    with ExpressCard.
    USB video capture dongles from scanny work pretty good too.
    There is a app that has FW recording capabilities - Isadora. As far as I have read it does not do great.
    And there is a screen capture option too. Search for VADE screen capture plugin.
  • traitdelumiere
    by traitdelumiere » Wed May 12, 2010 4:32 pm
    Thanks Vanakaru,
    As you said, mxo2 apparently works using a dvi to hdmi converter.
    I'll try this week with an intensity pro/mac pro config to tell you if it works too.
  • traitdelumiere
    by traitdelumiere » Wed Jun 02, 2010 4:26 pm
    Hi!
    Record from a macbookpro DVI output to a macpro/intensity card works perfectly
    via a cable dvi/hdmi.
    i did it with a FCP station and got sound from intensity analog inputs.
    traitdelumiere - johann
