Modify the default presets in Record to disk
  • Paul Sellis
    by Paul Sellis » Wed May 12, 2010 3:03 pm
    I need to record To disk during a performance with my MacBook Pro.
    I know that its CPU and Disk consuming but I need to display just recorded loops.
    But each time to configure Modul8, I need to modify the default parameters to
    Apple Photo JPEG
    25 fps
    480x360
    75%
    and so on...
    Is it possible to modify the default preset in Modul8?
    A kind of XML file somewhere?
    Thanks for your help
    Paul
  • Paul Sellis
    by Paul Sellis » Sun May 16, 2010 10:13 pm
    No support?
    :cry:
    by vanakaru » Sun May 16, 2010 10:42 pm
    Paul Sellis wrote:No support?
    :cry:
    I am with you. But no solution.
    Actually I do not understand your problem. You mean Capture to Disk, don't you. When I set this up the way I want and start and stop capture without restarting M8 the settings stay the way I left them. I just need to name new file.
    I have pretty good MBP, but I can not capture the output at 640x480 without seriously stuttering the output. What beast of a mac you have that lets you project smooth output and capture it the same time.
