getDMXValue syntax
  • traitdelumiere
    getDMXValue syntax
    by traitdelumiere » Thu May 27, 2010 6:17 pm
    I'd like to create some modules using DMX.
    can you help me with the syntax and use of : modul8.getDMXValues
    Is there any dictionnary for modul8 python??
    (nothing in the user manual)
    thanks
    johann
  • traitdelumiere
    by traitdelumiere » Mon May 31, 2010 6:48 pm
    please Help!
    Python itself is not the heart of the problem,
    The real trouble is :
    Modul8 manual is a 2.5 one.
    So there is nothing to explain how to use the 2.6 specifical functions ;
    (getsoundbands, getlevelinput, sendDMXvalue, getDMXvalue…)
    I found some answers reading the forum, but nothing clear about modul8.getDMXvalue…
    :cry:
    by sigmasix » Mon May 31, 2010 11:23 pm
    DMX messages arrive in the DirectEvent script. The type returned is 'DMX' and the param dictionary contains these values:
    Code: Select all
    {'universe': 0, 'value': integer, 'channel': value, 'timestamp': float}
    so if you want to print the value received from channel 5 and map it to a range between 0.0 and 1.0, you can use this code:
    Code: Select all
    if type == 'DMX': if param['channel']==5: print param['value']/255.0
    to send DMX value, you can use the sendDMX function wich has these parameters:
    Code: Select all
    modul8.sendDMX(universe, channel, dmxValue)
    universe is 0 for now, and value is between 0 and 255.
    david
    by david » Tue Jun 01, 2010 11:13 am
    To add to Eric's answer, in a Module, to get the received value, you could use :
    modul8.getDMXValues(universe)
    for now, universe is 0
    this function returns an array of 513 values.
    However, using DMX DirectEvent is the best way to go as you get the info as it is received.
    A note concerning channel numbering, in DMX, channel 0 is a special channel and you should (normally) not use it (on send/receive). So, usable channels are from 1 to 512 inclusive.
    DMX DirectEvent and modul8.sendDMX(universe, channel, dmxValue) uses the same numbering.
    Regards
    David
  • traitdelumiere
    by traitdelumiere » Tue Jun 01, 2010 6:58 pm
    Hi david and Sigma,
    Many thanks for your answers and for the job you did on modul8.
    Please, continue to go on that way!
    johann
