new module [pls] v4
    pls
    new module [pls] v4
    by pls » Wed Jun 09, 2010 10:17 pm
    allows basic controls of the edirol v4 within modul8..
    for correct hardware and MIDI settings check the manual below..
    actually i'm not quite sure concerning the input select and the memory select, cause these need a MIDI program change which isn't supported in m8 right now..
    but i could manage to simulate this message by sending three MIDI CC.. would be helpful if someone knows a better way to do this..
    for now it's working.. but be careful with sending to many stuff at the same time..
    yes.. the v4 can crash.
    anyway. enjoy..
    and check out my workshop at AViT Berlin 2010 if you're around..
    http://festival.visualberlin.org/day-program/
    greetz
    pls
    MIDI OUT from your computer should be connected to MIDI IN of V-4
    Receiving MIDI channel on V4 should be set to 1
    -> MENU -> MIDI SETUP -> MIDI Rx CHANNEL
    V-LINK should be off
    -> MENU -> MIDI SETUP -> V-LINK
    Note Mode should be off
    -> MENU -> MIDI SETUP -> NOTE MODE
    V-4 Mode should be set to “Normal Mode”
    -> MENU -> UTILITY -> V-4 MODE
    MIDI assignments in V-4 should be following..
    Effects-A1 Assign -> cc 1
    Effects-A2 Assign -> cc 2
    Effects-A3 Assign -> cc 3
    Effects-A4 Assign -> cc 4
    Effects-B1 Assign -> cc 5
    Effects-B2 Assign -> cc 7
    Effects-B3 Assign -> cc 8
    Effects-B4 Assign -> cc 9
    Video fader Assign -> cc 10
    Transition Assign -> cc 11
    Transformer-A Assign -> cc 12
    Transformer-B Assign -> cc 13
    BPM/Sync Assign -> cc 14
    Output Fade Assign -> cc 16
