downloaded modules not saving
  • mowgli_uk
    by mowgli_uk » Fri Jun 11, 2010 1:00 pm
    I recently installed md8 on my new macbook pro running OS x 10.6.3 and I'm having issues with modules and workspaces.
    Modules downloaded from the online library are not present after closing and re-opening md8 even after clicking on the button to save module changes.
    Also my workspaces are not getting saved either.
    I've never had this issue before. Any ideas?
    by ilan » Fri Jun 11, 2010 1:43 pm
    Try checking then changing the permissions on your modules folder.
  • mowgli_uk
    by mowgli_uk » Fri Jun 11, 2010 1:51 pm
    That did it. Thanks!
