module DMX layer fixture
  • Mathouston
    by Mathouston » Sun Jun 13, 2010 1:29 am
    Is there the good place to ask about the new module DMX Layer fixture ?
    I've got a problem with this module.
    When you use the keyword ctrl_layer_position_x in the Dmx Layer fixture module, it is not possible to move the layer
    in the negative position such as x=-100
    The layer position start from the center of the output. You can't move the layer in the upper left corner of the output by DMX.
    That's the same with the keyword ctrl_layer_position_y.
    Any solutions ?
    Thanks for answer .
    Mat
    from France.
    by ilan » Wed Jun 16, 2010 4:50 pm
    Hello Mat,
    I received your message on the support system and have assigned it to your DMX module guru, Boris.
    Best,
    ilan
  • ceevi
    by ceevi » Fri Nov 12, 2010 4:04 pm
    any updates aboute this issue ?
