zoom unzoom constant speed
    sadcrew
    by sadcrew » Tue Jun 15, 2010 8:05 am
    Hi there!
    For a specific project, I have to zoom and unzoom in an animation, M8 give some good result with the autoscale. The only problem I get is about the speed, when the size is very small the speed is getting higher, I get the feeling my animated object is flying away. Is there a way to have a constant speed during the zoom/unzoom?
    Thanx for advices,
    Arnaud
    SAD
  • anomad
    by anomad » Wed Jun 16, 2010 4:15 am
    . it sounds like you have the zoom set to 'smooth' - try changing that to 'linear' (i'm not sure of the exact names, i don't have modul8 on this system...)
    -james
    (a nomad. )
    sadcrew
    by sadcrew » Wed Jun 16, 2010 9:14 am
    Smooth is the mode giving the best result compare to linear, but I was looking for a trick to make it more constant. A very small object will look going faster than a very big, that's the reason I need to slow up the speed when the object is further from the camera point of view. it's kind of difficult to explain..
    Hope I make it clear.
    Arnaud SAD
    by sigmasix » Wed Jun 16, 2010 9:40 am
    it's only a matter of visual illusion. It's actually not going faster, but the fact that it's smaller looks like it's going faster… If your good with maths, you can imagine a function that does a half sinus so it's slowing down when it goes small but not when it goes bigger, doing a module for that is a real piece of cake as long as you have the function :wink:
    sadcrew
    by sadcrew » Thu Jun 17, 2010 10:19 am
    Thanks Sigma for the explanation, I get the idea, it makes sense (even I hate math). The thing is I'm bad in programming this kind of stuff, I guess if someone build it, it will help the whole M8 users (no, I'm not the only one looking for this function, no..).
