Mini Display port to Component cable-Help
  • Hey!Cliché!
    by Hey!Cliché! » Fri Jun 25, 2010 11:02 pm
    So I have a new weekly party that has been offered to me, and being that this is how I make a living, I can't really turn it down because of one little problem. That problem though is giving me a huge headache.
    The entire video system (one projector, five or six HD TV's) are all connected using component cable. I have a unibody Macbook Pro and an adaptor for everything, except this. A simple VGA to Component cable doesn't fix the problem, so before I go buy anything else, I want to know what you guys have used, or if its not possible. Thanks.
    Hey! Cliché! video club
  • Vibber
    by Vibber » Sat Jun 26, 2010 11:08 am
    here:
    http://www.garagecube.com/forum/viewtopic.php?t=4832
    same discussion. Although you might need one of the upper end scan converters to get component out
  • Hey!Cliché!
    by Hey!Cliché! » Sat Jun 26, 2010 11:46 pm
    Not really the same discussion, thats more about s-video/RCA's. I want to know an actual scan converter or what have you that does Component cable.
  • Be
    by Be » Sun Jul 04, 2010 3:44 pm
    Have you tryed this:
    http://www.blackmagic-design.com/products/intensity/
    Only prob is to swith usb3.0 to 2.0 but i've seen it working with MB pro's.
    Good luck .)
    expect unexpected
