hi there i have the same problem, and a clean install, i bpught my new mac pro, bought M8, install the software and begin with my projects, but some of them doesn't load all medias at all... 1 of 4 projects loads ok, other 3 loads only some .mov videos, but swfs ans jpgs loads ok. some thing i can see is that if i try to delete the affected layers and recreate them doesn't play that medias, but if i create another cues (3 instead of 2) and create the layers it will play the medias with no problem, but if i save the project and launch again, have the same problem, i think it's a problem with that media files, but tried with another wich works on other projects and have the same result.... i can't understand what happened with M8. and the team, which appears to doesn't take care of bringing some support to this.Hi sigmasix,
I removed the modul8 preferences, but still can't get it work.
I also have M8 v2.5 in the same system, and it works fine.
would it be any incompatible problem of these two version?
thanks a lot!
Also instead of having multiple copies of your media for all projects make reference mov with Quicktime>Save As>Make Reference Movie. It is about 4kb and loads the original movie where ever it resides.you should always keep your project file in the same folder as your content.
try this it might fix it.
Yea, either that or hard links. Explanation here:Also instead of having multiple copies of your media for all projects make reference mov with Quicktime>Save As>Make Reference Movie. It is about 4kb and loads the original movie where ever it resides.
I never got this working. Also tried once again with no success. Would be ineresting to know if somedody can do it.Yea, either that or hard links. Explanation here:Also instead of having multiple copies of your media for all projects make reference mov with Quicktime>Save As>Make Reference Movie. It is about 4kb and loads the original movie where ever it resides.
http://www.udart.dk/2010/02/22/modul8-q ... ith-links/
The advatage of hard links is that even if the original is moved or even deleted the link will continue to work.
