Video Streaming recognition
  • pcultural
    by pcultural » Wed Jul 07, 2010 9:20 pm
    Hi, I would like to live manipulate live streaming videos on modul8, like, embedding UStream URL or making modul8 recognizing it as a live cam. How can I make it possible?
    thank you!
    p.
  • albanoalfredo
    same question
    by albanoalfredo » Wed Oct 13, 2010 12:09 am
    did you find any solution?
    I'd like to use a Ustream video embedded as a layer on Modul8
    maybe some module could help, I think it would be very easy to develop, but I dont know any python
    david
    by david » Tue Oct 19, 2010 12:53 am
    Hi all,
    I do not know which format USTREAM is streaming its data.
    But if you have an RTSP stream, here is the way to get it into Modul8 :
    says that your stream is rtsp://203.125.227.74/3gpp
    1) create a text file named myvideo.mov, write this inside :
    RTSPtextRTSP://203.125.227.74/3gpp
    2) if you have a QuickTime Pro license, launch QuickTime Player 7
    Open URL... (rtsp://203.125.227.74/3gpp)
    Save As... self-contained movie (myvideo.mov)
    Then you will be able to open myvideo.mov to access the live stream
    Regards.
    David
  • albanoalfredo
    by albanoalfredo » Tue Oct 19, 2010 4:50 pm
    Thanks David
    I´ll try to encapsulate the .flv link from ustream in quicktime pro and import to modul8 as soon I have quicktime pro with me
    david
    by david » Tue Oct 19, 2010 5:54 pm
    Ah, ustream is using flv format ... flv is not supported by QuickTime.
    tdog
    by tdog » Tue Oct 19, 2010 6:54 pm
    'perian' plugin for quicktime solves that problem
    http://perian.org/
    tdog
  • teletoby
    Iphone Cam to M8
    by teletoby » Sat Oct 30, 2010 9:53 pm
    iWebcamera for iPhone is a cool App.I test it with Modul8. Perfect!
    http://www.drahtwerk.biz/EN/Home.aspx
    by The Midi Thief » Wed Aug 10, 2011 9:25 am
    I'm still thinking about this. It would be really nice if I could stream video from one place to another using an existing streaming service like Ustream or Bambuser. Yes they use flv video and yes I can get the flv to work in quicktime with Perian but...
    1. How do I figure out the address of the flv-files for Ustream and Bambuser?
    2. Ok, I can get a FLV to play in Quicktime but how do I a live streaming FLV to play inside Modul8? Do I need to make a container movie like in David's RTSP example?
    3. iWebcamera, yeah that works but I need to connect a better camera. That's why it would be nice to use Bambuser.
    So what I am looking at is finding a streaming service that can use a video camera (connected to the computer) as source and the the stream should be compatible with quicktime and playable in Modul8.
Users browsing this forum: Baidu [Spider] and 17 guests
