layer speed bug?
  • monsho
    layer speed bug?
    by monsho » Fri Jul 23, 2010 5:30 pm
    Not sure if this is an actual bug or if I have a setting wrong somewhere, but when I save a set and re-open. the speed of each layer is set to 0 even if I have reset it and saved. Happens on all sets I save....
    version 2.6.1 on non unibody MacBookPro, osx 10.6.3
    Any ideas?
    by sigmasix » Sun Jul 25, 2010 1:59 am
    try to deactivate all your modules, it must be something from a module
  • monsho
    by monsho » Mon Jul 26, 2010 1:36 pm
    sorted, yep, had several modules activated, turned them all off and fine - cheers for that!
