How to set map to do interative image?
    ellenpan
    by ellenpan » Wed Aug 11, 2010 8:53 pm
    This may be a rather too simple question to most users here.
    I saw a great gig excerpt on garagecube blog:http://vimeo.com/13325766
    I tried to do something interactive like that but then found the clip is either loop or for once only.
    How to set M8 to play each clip (but not in a loop mode) as one trigger the individual clip?
    and obviously not by turning on/off the layer.
  • anomad
    by anomad » Thu Aug 12, 2010 3:51 am
    . maybe try setting the loop to play once, then every time you want to trigger it set the ctrl_layer_movie_positionIn to 0.0 (it will restart the clip)
    -james
    (a nomad. )
    by ilan » Thu Aug 12, 2010 11:44 am
    - Set playback to 'play once'
    - Bind the pad to trigger the clip as clicking on the thumbnail in the media set always re-triggers the media
    No need for a module.
    Just make sure that all of your clips begin where you want them to begin.
    birdiedaboy
    by birdiedaboy » Fri Feb 25, 2011 6:52 pm
    this was the answer he gave me on his vimeo clip when i asked him about the process
    Steye 12 days ago
    Hey abraham,
    Thanx for the compliment!
    this an idea I've been having for 10 years or something but now I could finally do it! my chain is:
    logitech rumble pad
    connected to a max 4 life patch that translates it to midi that triggers samples in ableton live and the midi also trigges clips in modul8
    very simple but effective!
    Repeat after me: I am free
