dim output signal ?
  • afreemind
    dim output signal ?
    by afreemind » Tue Aug 24, 2010 12:48 am
    i have a simple question - how can i dim my output signal via md8 during the performance if the projection is to bright ?
    by ilan » Tue Aug 24, 2010 6:12 am
    Master Alpha. Bottom right side of the main interface.
  • afreemind
    by afreemind » Tue Aug 24, 2010 6:41 am
    yes - if i use a single layer it will work.
    but if i compose my output picture with different layers and use the master alpha button it doesent work...
    deepvisual
    by deepvisual » Tue Aug 24, 2010 12:21 pm
    Something strange happens if I dim the master alpha with multiple layers.
    I get the obscured layers bleeding through.
    they should be hidden by the top layer, but come through.
    this also happens with the x fader.
    and no, they aren't set to lighten..
  • afreemind
    by afreemind » Tue Aug 24, 2010 12:27 pm
    i think this must be improved
    i should have full controll over the outputsignal - lightness/contrast/saturation/etc ...
    by vanakaru » Tue Aug 24, 2010 1:06 pm
    I think it is time for you to write a module that will control your output the way you want.
  • afreemind
    by afreemind » Tue Aug 24, 2010 1:11 pm
    if i could - i would ; )
    maybe someone is in the mood ?
    by ilan » Wed Aug 25, 2010 9:17 pm
    Would 1 knob that fades all the layers at once solve the problem? Or do your layers use different alpha levels from each other?
