16:9 advice
  • vgem
    16:9 advice
    by vgem » Wed Aug 25, 2010 2:26 pm
    Apologies if there's already a post on this... But i can't seem find one.
    So, the problem is that I'm now filming in 16:9 and all my old clips are 4:3.
    Does anyone have any tips for integrating the two? The only thing I can think of is to start using 16:9 clips, but keep the 4:3 output and simply allow for the cropping of the widescreen clips.
    In 4:3 I've been exporting as Photo Jpeg 512 x 384. What dimensions would you recommend for 16:9.
    Any tips / experiences / lessons welcome.
    Thanks,
    Gemma
  • Be
    by Be » Mon Sep 06, 2010 12:28 pm
    you can always stretch, but it depends on content .)
    expect unexpected
