moving 2 layers in different directions via MIDI
  • kisiel_k
    by kisiel_k » Fri Aug 27, 2010 10:56 pm
    Hi! I want to control 2 layers independently,for example via midi (something like directional light spots in theaters). I've found some layers that can use MIDI for controlling the position of a layer, but i can use it only for 1 layer. The option "layerset + position" as i've seen doesn't work for moduls from online library. Is there any way to fix my problem?
    I would be very, very greatful for any help.
    Regards, Jacek
  • anomad
    by anomad » Sun Aug 29, 2010 7:57 pm
    . when i want to control more than one layer at a time from a single module, i create a 'global' module and address the layers specifically.
    . you could create a slider element then in the module code have it affect two different layers independently
    -james
    (a nomad. )
