modul8 doesn't save ?????
  • frederic
    by frederic » Sat Sep 11, 2010 9:00 pm
    hello
    big trouble, why modul8 doesn't memorize ? I do a set with a lot of transform resize effect etc... I use a total recall in case. After saving my project, I close it and open it again and surprise ! always the same big mess every setup it's change same for the totat recall. And curiously it save always the same mess...
    help please I ready to change of software
    thanks
    Fred
    ghostofelvis100
    by ghostofelvis100 » Tue Nov 02, 2010 2:31 am
    Hiya Fred,
    Your post is a bit vague.
    Can you explain which parts of your set doesn't work?
    Are you using any specific modules in your set?
    Do you have any modules running which are not visible?
    Andy T.
  • frederic
    by frederic » Tue Nov 02, 2010 10:37 am
    The problem was due to bugs in the modules. I desactivate all the module and modul8 save my changes.
    ghostofelvis100
    by ghostofelvis100 » Tue Nov 02, 2010 10:48 am
    Glad you sorted it out.
    It may be worth getting in touch with the authors of those buggy modules, if you managed to work out which was the offender... Or possibly listing them here perhaps?
    Andy
  • frederic
    by frederic » Tue Nov 02, 2010 11:22 am
    here the modules used :
    -movie controler (layer)
    -perspective transform
    -total recall
    I only keep the perspective transform.
