Infos about MotionPath (layer) ?
  • Paul Sellis
    by Paul Sellis » Tue Sep 14, 2010 4:43 pm
    I am discovering the MotionPath (layer) module because I need to animate a layer across my display. I am not sure but I suppose that it is the best module to do that.
    But is there a tutorial for this module because, if I have understood a part of the functionalities, I must confess that some are confused for me.
    Also I can't make a layer cross completely my 16/9 display (even if in Preferences I have 16/9 also for Preview Panel).
    It's also hard for me to get a fluid move. Mine is almost choppy even if I reduce Global speed.
    If you have any infos, please could you help me?
    :roll:
    by ilan » Wed Sep 15, 2010 2:16 am
    If you want to move the layer only in a straight line, try to use the Lay'Animator_0 1(layer) module. All you have to do is place the layer wherever you want it, record its position and then set another position, record and then press play.
  • Paul Sellis
    by Paul Sellis » Wed Sep 15, 2010 9:45 am
    Thank you for your answer.
    I tested the Lay'Animator_0 1(layer) module and got a complete crossing of my screens (tried on a 3x 4:3). Unfortunately, as for MotionPath (layer) module, I got a little bit choppy movement. I tried to reduce speed but couldn't go for a duration superior than 100...
    How could I get a smooth move ?
    by ilan » Wed Sep 15, 2010 11:02 am
    Questions:
    - Do you get the same choppy movement when using the animation FX?
    - What is the hardware configuration of your computer? RAM? video card? Mac Pro? MacBook Pro?
  • Paul Sellis
    by Paul Sellis » Wed Sep 15, 2010 11:30 am
    Yes same thing with animation FX:
    in fact the movement is almost smoothly but I notice very slight stops (or jumps in the movement direction)
    I have a MacBookPro Intel Core 2 Duo 2,4 GHz with RAM 4 Go and NVIDIA GeForce 8600M GT
    by ilan » Wed Sep 15, 2010 11:47 am
    And what are your settings or memory in the preferences?
  • Paul Sellis
    by Paul Sellis » Wed Sep 15, 2010 11:58 am
    Thanks for your patience.
    In Preferences I have the standard ones for Medias: 30MBytes, 80% and 128 MBytes
    But were you speaking of that?
    In my test I use a new project with only a layer with Modul8 Testcard on it.
  • Paul Sellis
    by Paul Sellis » Tue Sep 21, 2010 8:38 am
    I said something wrong?...
    :oops:
    by ilan » Tue Sep 21, 2010 11:02 am
    Hello Paul,
    I am so sorry. Very busy times.
    Can you please send a message to support at garagecube dot com and I will bring our programmer in to consult on this situation.
