Movies moved to left after saving
  • stivo
    by stivo » Tue Sep 21, 2010 9:05 pm
    Hi Guys!
    i have this weird problem. On a new MacBook Pro
    With 17" : i5 / 128GB SSD drive.
    Both versions:
    V 2.6.1
    V 2.5.10
    When is save a comp, the "auto Rotate" is switched on, and the speed is turned of. This isn't the worst part. But all my layers are moved 25% to the left (If ten enabled, then they all got moved to to left)
    Even the layer is mirrored....
    See here the result after the saving:
    please help, all my comps are useless...
    This problem isn't excising on my 15" MacBooks
    by sigmasix » Tue Sep 21, 2010 11:06 pm
    open modul8, pause every modules then open your file. It's looking a lot like something coming from a module…
  • stivo
    by stivo » Wed Sep 22, 2010 5:18 pm
    is was indeed a module causing this problem, named the:
    (VS) Tweak Position and Scale
    thnx for the fast reply
Users browsing this forum: No registered users and 46 guests
