Locked 6 posts Page 1 of 1
The CPU monitor displays very high usage?
  • garageRoot
    by garageRoot » Thu Jul 29, 2004 7:05 pm
    The CPU monitor displays very high usage even with only one layer ?
    Modul8 uses some threads that run very fast especially when Quicktime is used to decompress frames. When the CPU monitor shows full usage, it does not mean at all that Modul8 reached its speed limit. It simply means that Modul8 uses all your CPU power. However Modul8 may re-arrange its internal activity when new layers/movies/effects are added. In other words, do not use the CPU monitor to see if Modul8 reached its speed limit.
    Vincent-Pimousse
    by Vincent-Pimousse » Sun Apr 06, 2008 2:18 pm
    Is there any way to see if Modul8 reached its speed limit ?
  • mowgli_uk
    by mowgli_uk » Fri Aug 22, 2008 11:30 am
    According to Einstein Modul8 reaches its speed limit when it turns into light
    Vincent-Pimousse
    by Vincent-Pimousse » Sun Aug 24, 2008 10:38 pm
    mowgli_uk wrote:when it turns into light
    What do you mean please ?
    by ilan » Thu Aug 28, 2008 12:01 am
    He's joking.
    Modul8 does not reach a speed limit. Your hardware will.
    by vanakaru » Thu Aug 28, 2008 9:42 am
    it is nice wording with multi level meaning and can not be translated. and will loose the beauty when explained.
