Deinterlacing live video inputs.
  • freespirit
    by freespirit » Sat Sep 25, 2010 8:50 pm
    I'm wondering if there is a way to correctly deinterlace my live inputs (firewire ADVC/Matrox MXO2 etc.). I'm not always free to pick camera/video sources so I regulary get interlaced video sources. None of the capture devices have an option to deinterlace on input so I'm looking for a way to solve this in Modul8.
    I noticed some threads here where people recommend Pete's FF plug-in for this but that kills 50% of the brightness from the sources and for me that's even worse than the interlacing, because live cams from clubs are notoriously dark, so any lose of brightness is a no go for me.
    If there is a way to intercept the live input with some deinterlacing app before putting it to Modul8 I'm also interested.
    Any suggestions are welcome.
  • Smo King
    by Smo King » Mon Sep 19, 2011 12:09 am
    I am wondering if just you and me have this problem?
    This threat is about 1 year old and stil no response! I am trying also mxo2 mini and there are interlace lines. What is suprisig me is that they disappear sometimes and come a few min later again..?!
    I would be also very thankful for some suggestion.
    best,
    Smo
    deepvisual
    by deepvisual » Tue Sep 20, 2011 8:40 pm
    its the codec,
    try uncompressed YUV 422
    works fine for me
  • Smo King
    by Smo King » Wed Sep 21, 2011 8:56 pm
    thanx for your reply, i will check this out.
    do you have sometimes some bad freeze crashes caused by mxo2 mini too?
    specially, if i am changing the input-codec while m8 is up, i had a few real bad crashes.
    after closing m8 the cpu is still running hot in red zone and doesn´t get "normal" til i restart the computer!!!
    any suggestion?
    best,
    Omid
    express yourself and you are totally style!
    www.guru-records.com
    mbp 2core 2.4 ghz, 4 gb, matrox mxo2 mini, m8, madmapper
