modul8 layer copy not working since 2.6.1
  • primep
    by primep » Sat Sep 25, 2010 11:30 pm
    very irritating bug on 2.6.1.:
    Layer copy does not work. It makes a duplicate of layer, but duplicated layer is black. Same bug on my macpro and unibody macbook pro. argh. here is a screen capture video demonstrating the bug.
    otherwise great software
    http://www.helicam.fi/modul8_layercopy_issue.mov
    -v[/url]
    by vanakaru » Sun Sep 26, 2010 8:30 am
    I do not have this problem. All works as it should. The only thing I can think of is that you may have a modul active that causes this. Try quitting all open modules if you have any open. Check Modules>Show>ones with orange play sign. Sometimes I close module window, but it is running still on the background.
    Anyway, it is just a quess.
  • primep
    by primep » Sun Sep 26, 2010 10:52 pm
    vanakaru wrote:I do not have this problem. All works as it should. The only thing I can think of is that you may have a modul active that causes this. Try quitting all open modules if you have any open. Check Modules>Show>ones with orange play sign. Sometimes I close module window, but it is running still on the background.
    Indeed I thought I had gone thru al modules, but it was crop layer (udart) causing this issue. when copied it fully crops the layer. thanks!
    parimat
    -v
  • Vibber
    Re: modul8 layer copy not working since 2.6.1
    by Vibber » Tue Feb 28, 2012 2:29 pm
    I have become aware of this problem and uploaded a fix of the module to the library today.
    Please let me know if you experience any other issues with this module.
    -Vibeke (Udart)
Users browsing this forum: Baidu [Spider] and 9 guests
