Render logical record V2.6
  • versicolor
    by versicolor » Mon Sep 27, 2010 2:39 pm
    I'm having issues with rendering the logical record. I get a black movie and the layers appear empty in the controls. Anyone else have this? It plays back perfectly well as a logical record otherwise (except i don't recall having to re-record the layer recorder before in 2.5).
    by The Midi Thief » Mon Sep 27, 2010 10:53 pm
    Do you objects in your composition that are depending on sound input?
  • versicolor
    by versicolor » Tue Sep 28, 2010 9:27 am
    Sort of, The SoundScrubber module is in use but set to random. This seemed to be recorded as points on the timeline though. It seems likely that it's confusing things.
    I managed to get it working though by using the following sequence:
    1. Record a set on the layer window. Stop it
    2. Start recording from the global logical recorder.
    3. Turn off modules
    4. Start the rendering
    After doing that once i've had no trouble rendering, even with modules running. Weird...
