Can not Render with the Module Painter
  • M.150
    by M.150 » Mon Oct 04, 2010 12:20 am
    my Problem is, i can not Render a short Videoclip with the Module Painter in the Logical Render Mode. Only Capture to Disk works, but it very bad to render something whit it.
    Any help??
    Thank You!!
  • M.150
    by M.150 » Mon Oct 04, 2010 2:06 pm
    no Support???, Help... :(
    by vanakaru » Mon Oct 04, 2010 3:58 pm
    If you think how Render Logical Record works you see that all live effects could not be rendered. You could use screen capteure instead. These are rather cood quelity now days. iShowU HD is good, but expensive, B-L-A-C-O-P is excellent and not so expensive, Vade's screen capture pluin is free and as good as the others.
  • M.150
    by M.150 » Mon Oct 04, 2010 4:24 pm
    What a bummer,... Can you post a link to B-L-A-C-O-P, please?
    I think, for a good resolution, these programms are not very good?!
    thank_U :D
    by vanakaru » Mon Oct 04, 2010 5:45 pm
    http://b-l-a-c-k-o-p.com/GrabberRaster.html
    Actually I find screen capture apps OK quality. If you want to record what is going out to the projector try Matrox http://www.matrox.com/video/en/products ... mily/mxo2/
