I meant module. I don't think the paint does want I want. That allows me to paint on the video right? I'm looking for something where I can use glow sticks to leave longer trails for performance videos. Thanks for the reply.Hello Lye,
I am not sure what you mean by delay 'program.' There is the Paint module and there are several modified versions of it in the online module library.
Another technique is to create a small dot in Photoshop and use it as a 'brush' and then turn on the 'trace' function.
Thanks guys! I will play around with this when I get home. I'm excited to see the results. A preemptive question though, is there anyway to increase the amount of trace I can add?- Enable trace
- Use a blend mode on the layer using video input
- Tweak brightness and contrast as needed
- Control the opacity of the layer to determine how long you want the image to remain visible. Setting it on full will make it permanent.
I meant past the limit of the knobs max of course.mmmm let me think... with the trace knob!A preemptive question though, is there anyway to increase the amount of trace I can add?
